Hydrogen Embrittlement determination
How to prove that the defective samples such as screw, bolt, threaded bar and nut failed because of hydrogen embrittlement? What kind of test can be done for this purpose? Thanks.
Lim Wei Heong
- Gurun,Kedah,West Malaysia
A few tests proposed by ASTM, you could refer their publication for detail methodology.
chee hong lee
Chee Hong, Lee
There is a simple test called Head Soundness Test. The Test specifies that the screw head is hit by a hammer, so as to bend up to 10 degree and there should be no breakage or crack.
D.B.Prabhu Ram
- India
