Copper Plating for nitride stopoff (India)
Dear sir
I give below a question for your due consideration and guidance, which will be of great help to me.
I am RAMAKRISHNAN NAGARAJAN, an engineer.
I am now working on a project to find out a practical method of Gas Nitriding to minimise expansion of steel components while gas nitrding. In that process, I realised that copper plating can inhibit unwanted areas from get hardened as it prohibits nitriidng in those specific areas copper plated. Since I am a learner, I am unable to get guidance on correct method of copper plating which completely inhibits copper plating. I realise that due to poor quality these areas also get hardened. Different hardness at different places. We use Rochele copper salt (cyanide solution) for copper plating.
Can you suggest a correct procedure which ensures no porosity in copper plating. What shall be minimum coating thickness?
Ramakrishnan NagarajanCALCUTTA, India
Use the rochelle bath for the initial 2-4 micron thickness strike which has to be alkaline. Follow it up with 30-40 microns of copper from an acid (copper sulphate) based bath .
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
