Copper plating not bonding to steel object
Requesting answer to what I'm doing wrong in plating a steel product with copper sulphate this on eBay or Amazon [affil links] in a sulfuric/water bath. It appears that steel is taking the copper and lays up a nice layer of copper and it is a light color (not burned), however somewhere in the process this "foil" seems to slide off and floats to bottom of bath. I have even used a flashlight battery as I suspected the voltage was too high originally..but it slides off eventually too. whats the problem..too much acid.. not enough water. what concentrations to a gallon bath would be appropriate. Could the acid be burning up the bonding of copper to steel.
What would be an alternative to prevent rust from forming on say a steel knife. Looking for an easy simple solution.
Harold J. Durant
- Prince Edward Island, Canada
simultaneous replies 2002
Here's four possibilities:
First, the knife may actually be stainless steel in which case it is impossible for you to plate it in this casual fashion.
Second, the knife isn't clean. Wear rubber gloves this on eBay or Amazon [affil links] and scrub it with a brush and pumice this on eBay or Amazon [affil links] and detergent or Soft Scrub [affil links].
Third, the knife is steel and it is clean, and this is the best you are going to do from a copper sulphate bath because copper "immersion deposits" on steel.
Fourth, if the knife is steel and it is clean you should be able to somewhat improve the adhesion and limit the non-adherent immersion deposit via "hot entry". That means attach the wire after cleaning, and turn the power on, and make sure the steel does not see the copper sulphate solution except when it is already electrified.
I'm not sure of the question. Are you plating knife blades with copper or do you want to prevent rust? Delete the sulfuric acid from your plating solution. Immerse the steel in a phosphoric solution (available from Hardware or Home Centers as an etchant/metal-prep) for about 15 minutes. Rinse well then plate. DO NOT touch the surface before plating.
If you want to keep the blade from rusting, use polished stainless steel. You can also polish hot-rolled and cold-rolled steel that will maintain a nice look for a long time. Longer, if you can keep a light coat of oil on it. I've polished hot-rolled steel to a chrome-look finish for tool parts. These have lasted for years with a light coat of oil.
Ken Kopsky
- Lytle, Texas
