Electroplating Testing Standards
Hi,
We want to know testing procedures or STD. available to test electroplating quality after electroplating has been done on any metal surface.
Kindly Feedback ASAP.
Thanks & regards,
Thakur SandeepCeletron India - Mumbai, India
First of two simultaneous responses
Mr. Sandeep, I think you need to hire a local plating consultant. There are hundreds of tests of plating quality, from salt spray tests and a dozen variations on them, to abrasion tests, hardness tests, thickness tests, porosity tests, ductility tests, adhesion tests, and on and on.
Second of two simultaneous responses
First off, you should be plating to a specification. They have a QC section. Second, did you stop to consider the number of metals that are electroplated? Quality checks for platinum plate are vastly different than iron plate. Further, the checks for cosmetic gold are a lot different than functional or industrial gold plate.
Your question is like asking how to fix engines, much too wide.
