-----Foaming from chrome suppressant
Q. The water we use for rinsing our chrome plated parts goes to an evaporator to allow us to evaporate off the water, we start the process at approx. 10-15 grams per litre of chrome,and stop the process when we reach around 250 g.p.litre. The problem we have is foaming in the tower and collection tank, this is caused by the suppressant we add to the chrome plating tanks,. this gets transferred into the evaporator with the chrome rinse water,we are trying to find a way to stop the foaming which slows down the evaporating process, does anyone have any answers?
- Springfield
A. You might try sending the solution feeding the evaporator through activated carbon. Unfortunately, if you remove the expensive foam suppressant, you will have to replenish it. LK
Lyle Kirmanconsultant - Cleveland Heights, Ohio
A. Unfortunately, the additive is doing what it is intended to do, create a foam blanket. In the bath it keeps the mist down, which is good. But in your evaporation step, it slows the volume reduction, which is bad. That's a common problem with recycling and waste treatment operations - you're often trying to accomplish the reverse of what the process solution does while in service. ![]() Dave Wichern Consultant - The Bronx, New York A. Firstly, why not try to recover more rinse waters before evaporation. That said,what do you do with the rinse water from the evaporator? If it is being concentrated for disposal, use a defoamer in the evaporator BUT do not do this if the water is being returned to the chrome tank. You may find it necessary to use a different type of evaporator,such as a "paddlewheel" instead of packing type. Gene Packmanprocess supplier - Great Neck, New York |
Chrome Bath Foaming
Q. We recently replaced our chrome bath solution. Since start-up 3 weeks ago we have been struggling with excessive foam on the tanks resulting in Hydrogen pops. We are using a non-foaming mist suppressant but the foam is more that 10"-12" thick at times. What can we add to get the foam reduced? What could be the cause?
Gerry Marchese- Beamsville, Ontario, Canada
August 8, 2016
A. Gerry,
This problem easy to fix, try to turn down amps 50-100 amps in chrome before the bar or rack pick up.
Good Luck
Popatbhai B. Patel
