How Can I Remove Tarnish/Corrosion From An 1800's Fireplace Insert?
I have just purchased a fireplace insert made by Peerless in the late 1800's. It is corroded, but underneath the corrosion appears to be a copper tone. I do not want to ruin it and would appreciate any suggestions on how to best restore it myself - not professionally. Is there a chemical, abrasive, or some agent that will remove the surface blemish so the original beauty can be seen?
Beverly Ann Alloway- Findlay, Ohio
Hi, Beverly. You should be and apparently are trying to find any info you can on this unit before setting to work on it. I would be surprised if a fireplace insert was made of copper or bronze; I'm not personally aware of them being made of anything but steel or iron. So, is there a chance that "copper tone" is just rust?
If it is rust, then
rust converter
⇦ this on
Amazon [affil links]
should be applied before repainting. Good luck.
August 14, 2008
