Electroplating onto rubber
Would you please tell me if it is possible to do electroplating on rubbers like silicon or nbr rubbers.
Saeed Shaghaghi
- TEHRAN, IRAN
Everything is plateable, Saeed. It's a question of whether the adhesion is sufficient for the application though.The first issue in plating on non-metallic surfaces is figuring out how to etch them so the plating will grab tight.
Of course there is also a second issue that plating tends to not be very flexible, so I have a hard time picturing a plating on silicone that is going to be good for much. Good luck.
