Corrosion problem where aluminum cathodes are bolted on anodize tank
anodizeusabannerCathodes
"No-Ox-Id" Compound
no_ox_id
Q. In our anodize tank, we use aluminum cathodes. The cathodes are bolted to an aluminum carry bar in close proximity to the sulfuric acid anodize solution. We are concerned with corrosion at the joint of the cathode & the carry bar. We are looking for a suggestion for a conductive grease or something else to avoid corrosion.
David A. Kraft
- Long Island City, New York
A. Dave.. contact Drew Nosti, I believe he has what you need.
Marc Green
Marc Green
anodizer - Boise, Idaho
A. Cheap and effective: wrap it with heavy duty aluminium foil. Change as required.
