Are pans safe after removing Teflon?
When Teflon coated pans start to wear through and show the underlying pan's metal can the Teflon be removed and the pan used as a plain metal plan. If a stainless steal or aluminum pan has a Teflon coating and the coating is completely removed (sand-blasted?) is the pan safe to use?
Frank Mabry
- Cornwall on Hudson, New York
Is it unwise to continue using a pan with a scratched teflon coating?
David Dorsey
- Atlatnta, Georgia
Some people worry about aluminum poisoning, gentlemen; you'll see many threads here on that topic. Personally, I don't.
I still research this this objective.Here is one opinion, it is not mine.
http://www.fda.gov/bbs/topics/CONSUMER/CON00036.html
Roumen Jeliazkov
- Hampton, Virginia
Hi. Thanks for the excellent article, Roumen.
August 29, 2008
