Black or darker base coat for Zinc and Black Chromate plating
Q. We have a customer who is using a Zinc and Black chromate plating finish on thread fasteners. When the customer installs the thread fastener with the provided recess, they chip/remove some of the top coat, black chromate in the recess which leaves the zinc base coat showing. When the zinc base coat is showing the parts are not acceptable. My question is, is there a finish that has a black or darker base coat that could he process with a black chromate and black chromate and offers the same corrosion resistance or better. At least with a darker base coat, when the black topcoat is removed the fastener recess it will not look or stand out as bad.
Bill Bryan- Rockford, Illinois, USA
A. The problem occurs due to : ![]() Asif Nurie [deceased] [deceased] - New Delhi, India With deep sadness we acknowledge the passing of Asif on Jan 24, 2016 A. Black chrome as featured in the AnoBlack Cr data sheet at our website and widely available from other shops has been used for the heads of fasteners used to hold avionic controls in aircraft cockpits. The more abrasion resistant black withstands rigors of repeated assembly and adjustment. Alternatively, you may try a salt bath nitriding process such as QPQ from Kolene. It achieves a black nitride surface that is superior to any plated coating. ![]() Milt Stevenson, Jr. Syracuse, New York |
A. You can use black oxide on the zinc - preferably the hot version. Look for a vendor in the finishing.com supplier listings.
Dan Brewerchemical process supplier - Gurnee, Illinois
