Lacquering on plated plastic component
Can you please tell me the process of lacquering on plated plastic (PC ABS) component. Mainly we are failing on the adhesion test after lacquering.
Thanks in advance,
Manish
- Pune, India
What metals are you plating onto the plastic, Manish? If nickel-chrome, why would you lacquer?
Hello Manish,
There are several routes to your question.
1) Dip application.
2) Spray application
The materials are:
PU
Acrylic
Mixed PU acrylic
Your enquiry does not carry much info on end use or the type of plating, nor do you mention whether it is a 2 wheeler part or a consumer durable part and what test standards are you trying to meet.
Good luck,
asif_nurie
Asif Nurie [deceased]
- New Delhi, India
