How to paint brass beds, lamps, and fireplace doors
< Prev. page          (You're on the last page of the thread)
Q. I am trying to paint a fireplace screen made of a polished brass (lookalike) finish. A magnet does stick to the surface. Is there a way to paint the surface with a black matte finish? How do I prep the surface first. I am a total novice at all this...
Thanks in advance for your help!
Donald
Donald Popejoy
- Houston, Texas
January 26, 2009
A. Hi, Donald. Apparently it's brass plated, and it's hard to get paint to adhere well to brass. You need an 'etch primer' for metal. Once that is done you should be able to pick any color you like, including black, for the finish coat. But temperature can be a concern for a painted fireplace screen if it's functional. Choose a high temperature paint and keep your fingers crossed. Good luck.
January 27, 2009
Q. I have an old lamp which has part brass pieces and brass plated pieces which I have cleaned with by boiling vinegar in bulk on eBay or Amazon [affil links] and salt then cleaned with 00 steel wool this on eBay or Amazon [affil links] and sandpaper.
What type of paint should I use to refinish (not a brass shine finish but a flat color), and should I use a primer first before final painting ?
Harry Lockwood, PE
- Atlanta, Georgia
May 19, 2009
Q. Hi, my ugly brass fireplace doors do not allow magnets to stick. I did sand and paint them with a nice oil-rubbed bronze spray paint. It looks pretty good, but it scratches easily. I want to put a matte clear coat on it but there is some concern since they are fireplace doors. Lady at Lowe's told me that the polyurethane I bought could release toxic fumes if it gets too hot. The doors don't get super hot, I tested it last time we had a fire, but they aren't room temp either. Any suggestions on a good clear coat (really want it to be not-shiny)? Thanks!
Jen Wilton
- St. Louis, Missouri
September 19, 2009
A. Hi, Jen. I hate to say it, but I don't think the softness of your spray paint is the main problem that is leading to the scratching, but its minimal adhesion. If you didn't apply a self-etching primer before the spray paint, I think it will still scratch easily even if you clear coat it, because a chain is as strong as its weakest link and the paint isn't sticking well to the brass.
September 20, 2009
Q. I too want to paint my outdated, ugly brass plated fireplace doors. I would like to paint it black to look more like iron. I am wondering about painting the track where the doors slide open and shut. I don't know if the paint would chip off there. Is there any thing that would work in the track like a rubber coating, etc.
Lisa Scott
- Midland Texas
March 8, 2010
Q. I have several brass knick knacks, e.g., vases, figurines, etc that I would like to be able to spray paint silver. Will the etching primer and then a silver spray paint do the trick?
Ann Bruns
hobbyist - Leawood, Kansas
May 16, 2010
A. Hi, Ann. As you read above, getting adhesion on brass can be problematical. But the self-etching primer is the way to go and I would guess that the adhesion will be sufficient for this purpose. Good luck.
May 18, 2010
Q. I was curious about spraying an outdoor light fixture. Will etching paint and then spray painting it in an oil rubbed bronze finish work? or will weather, such as rain and snow, quickly wear the spray paint away?
Betty B [last name deleted for privacy by Editor]
- Arlington, Virginia
May 26, 2010
Q. My husband and I recently purchased a home built in the early 60's. I'm sure it was upscale when it was built, but it definitely needs some TLC. We're in the process cleaning it up. I have taken these wonderful interior panel doors down all over the house to strip several coats of paint off the wood. We thought all hardware was brass - a few pieces were, and they look good now that all the paint has been removed, but is there anything I can do with the hinges and pins that are now bare metal? I'm guessing they were only plated...? How can I make them look brass again? We're talking lots of hardware. Thanks!
Bert Bozarth
new home owner - Dillon, South Carolina
August 23, 2010
Q. How would you suggest painting/treating a steel fireplace screen to give it a brushed bronze look?
16430
Curt Longacre
Home owner - Concord, California
December 5, 2010
1. I have a brass figurine, which I want to paint or make dark blue or black.
I tried with self etching primer and black car spray paint. But when decorating the figurine, the paint comes off again.
I heard one can blacken the brass directly or even make it bluish. I am totally inexperienced thus any explanation should be really easy to understand and possible to make at home without expensive equipment.
2. As well I have seen a brass figurine painted partially with beautiful red and pink colours, which where more transparent or as well metallic? The look was as if the brass was shining through the colour, this looked really good. How can I achieve this effect?
Thank you very much for any help
Nameda K.
Hobbyist - Munich
March 1, 2012
A. Hi Nameda. You can get commercially available brass darkening solution this on eBay or Amazon [affil links] or 'brass black' [Brass Black on eBay or Amazon [affil links] . Many other colors are achievable with various chemicals, but you'd probably have to consult a book on patinas like "The Colouring, Bronzing & Patination of Metals" [on eBay, Amazon, AbeBooks affil links] .
July 2014
Q. I have two brass (magnet does not stick) and glass display cabinets. The brass strips seem to be attached in some way to the wood and is very secure. The look is very dated but I need the function of storage for my glass collection. I would like to paint these, perhaps white or a color. Please give me the products and techniques, as detailed as possible so I can convince my husband this is an option!
Thank you,Nancy
Nancy Burns
- Naples, Florida
March 23, 2012
Q. I want to paint a brass gramophone horn, a magnet doesn't stick to it. Thing is, I would like the possibility to have the horn return in its brass state if I get tired of the color. Is this possible, and if so, how would I go about doing this?
Adrik Sokolov
- Breda Noord-Brabant, Netherlands
March 24, 2012
A. Hi Adrik. Please determine if the horn is solid brass or brass plated steel. A magnet sticks to steel and will usually provide the answer.
Although it involves highly toxic chemicals which require rubber gloves this on eBay or Amazon [affil links] , goggles this on eBay or Amazon [affil links] , and good outdoor ventilation, methylene chloride based Aircraft Stripper will strip most paint off of metal without harming it. But brass plated steel gets perforated over the years, and the steel rusts through the porosity and pinholes, which will be aggravated by the painting and stripping. Good luck.
July 2014
Q. My mom has offered to give me the solid brass head and footboard I used as a child. It's the shiny yellow brass finish. I would like to refinish so it goes more in our decor. Not sure if/how this is possible. Can I spray paint it and achieve good results? I did find one company online that is not anywhere near Texas and they wanted nearly $1500 to refinish a head and footboard!
Nicole Souther
Hobbyist - Frisco, Texas
July 10, 2014
Q. I used a liquid deglosser on my brass fireplace and sanded a little and used steel wool and painted with high heat spray black and dried overnight and it seems to be scratching off. Could I just use the self etching spray now over the high heat and then paint it again with a new coat of high heat or am I up a creek?
Amy Patton
- auburn, Washington, US
April 20, 2015
A. Hi Amy. It can be tough to get adhesion on brass, but unfortunately if the black paint isn't sticking to the brass it won't do any good to have your next coat adhere to the black paint, as it will just come off together. Sorry.
April 2015
Q. Do you have any suggestions for what I should do now? Like sand off the black paint and start over with the self etching paint?
Amy Patton [returning]
April 21, 2015
April 2015
A. Hi again. It's very difficult to guess from a verbal description what is actually involved. You should probably sand off the black paint and then test the adhesion of the self-etching primer on a small spot. But when you're halfway through sanding, you'll be cursing and saying to yourself "Didn't that jerk who recommended this realize that ...?". Sorry, no, I didn't realize that :-)
Refinishing outdoor brass coach lights
Q. I have 3 brass outdoor coach lights taken from a high in hotel being remodeled. I took them to a silver Smith and had them re done. The finish was awesome,and shined like brand new brass. 10 years later they are dull and black rust is appearing on the frontage and corners. Can they be sprayed gold?
Charlotte Faraji
- Fort Washington
August 25, 2017
A. Hi Charlotte. If you are actually seeing rust, they are made of brass plated steel rather than solid brass. A magnet would confirm whether they are steel.
Yes, they probably can be successfully spray painted by using a self-etching primer first, and then following it with a brass-toned paint. But if you paint them instead of having them replated (if steel) or re-polished (if solid brass) they certainly will not look "awesome" and "shine like new brass" this time :-(
August 2017
Q. I am from India. I have many brass decorative items and they are old - most of them more than 100 years old. I tried applying brass polish and it is not effective. I read about coating the items with brass metallic paint. Do you think it will work and if so how long the shine will last.
Krish
subramania krishnamurthi
- Providence, Rhode Island
December 10, 2017
A. Hi Krish. If these items are solid brass I think it would be a shame to paint them :-(
Please see topic 47788, Removing oxides and chemical polishing for preteen brass auto lights", or topic 22177 "Polishing Old Copper Fire Extinguishers" to see what people do to restore old brass.
January 2018
ammonium citrate (5% pH 9) is perfect cleaning solution for old brass and copper. Everbrite [a finishing.com supporting advertiser] is probably best clearcoat for Brass you can find in USA.
Hope it helps and good luck!
Is it safe to spray paint the outside trim of a natural gas fireplace? I would like to paint the brass trim black.
Harri White
- Wilmington, North Carolina USA
April 21, 2019
A. Hi Harri. My ventless gas fireplace is built into a plain wood "mantle piece", so I'm sure it doesn't get really hot. High temperature paint should be more than adequate, although you'll probably have to start with a self-etching primer to get it to stick to brass. Good luck.
April 2019
