Plating Ni to copper surface
Hi,
Anyone knows how to plate Ni to the copper surface? Your answer will be a great help.
Jian Liu
Medical University of South Carolina - Charleston, South Carolina
"Nickel and Chromium Plating"
by Dennis & Such
ni_cr_plating_dennis%26such
AbeBooks
Hi Jian. There is no special trick to plating onto copper, but the subject of nickel plating does fill entire books, so it can't easily be detailed in a paragraph or two...
Please describe what article you are trying to nickel plate (there are many different nickel plating solutions), and how many (there are many different application methods including rack plating, barrel plating, and brush plating), and why. Maybe then the subject can be introduced in manageable length. Or go to your library and get a couple of plating books. Best of luck.
