  Thread 163/28
Zinc and Cadmium Plating Thickness Requirements
Out of various protective coatings for avoiding corrosion please inform if there is any International Standard for suggesting "minimum film thickness" of "Zinc plating with Yellow passivation" or Cadmium Plating, for Mild steel/ carbon steel parts used in machines.
If there is any feasible /economical solution equivalent alternative to above Zinc/ Cadmium plating , please suggest.(Apart from blackodizing/Ni/ Cr. plating)
DILIP P. MANOHAR
- MUMBAI, India
publicly reply to DILIP P. MANOHAR
Dear Dilip,
Please follow ASTM B633. This is a spec. for Zinc which is internationally recognized.
Hemant Kumar
Hemant Kumar
- Florida, USA
publicly reply to Hemant Kumar
