  Thread 161/88
Cleaning Brass and Copper
Looking for other suggestions to seal copper and brass. I have seen here the reference to Nycote [adv: Nycote on eBay] and was about to try a Clear Lacquer coat of paint.
I have found another way to clean the copper and brass. A product named Twinkle brass cleanerthis on eBay or Amazon [affil links] I have found at the local grocery store in two forms. One is a yellow paste that includes a foam applicator and is available in a 1.5 - 2 inch tall 3 inches around container as well as a thick pink paste that is squeezed from a 5 inch tall 2 inch around container and smells like baby powder.
Brasso this on eBay or Amazon [affil links] still works well but is hard to remove once applied ... try Twinkle on top of the Brasso this on eBay or Amazon [affil links] .
Also I had noticed a thick film on the brass which I presumed is a finish of lacquer. This lacquer can be removed with lacquer thinner this on eBay or Amazon [affil links] Warning! flammable! or MEK / methyl ethyl ketone. CAUTION Methyl Ethyl Ketone is very nasty and will melt just about everything and if applied with bare hands it can be tasted. But it does work. Another cleaning tip ... tomato anything left on copper or brass to dry will clean it well.
Tom Smith
- Garland, Texas
publicly reply to Tom Smith
Hi, folks. Tom's point about MEK, in case anyone misread it, was that you DON'T apply it with bare hands. MEK and methylene chloride require goggles this on eBay or Amazon [affil links] , rubber gloves this on eBay or Amazon [affil links] , and excellent ventilation (strong preference for outdoor application).
February , 2010
publicly reply to Ted Mooney
