Micro Porous Chromium
"Electrodeposition of Chromium from Chromic acid Solutions"
by George Dubpernell"
chrome_dubpernell
or eBay or
Q. We are testing pore density of microporous bright Chromium deposit by using Dubpernell test. Which involves plating of copper coat from acid copper bath over chromium deposit. The pores are visible as fine copper spots. Activation of chromium by immersing in warm dilute nitric acid is also recommended. We experience difficulties when chromium thickness is higher i.e. in excess of 0.5 microns. The pores are not visible even after activation. My question is whether we can expect same corrosion resistance from the systems showing negative / improper results of above Dubpernell test. What is the maximum permissible pore density for Micro Porous chromium deposit, minimum being 10000 pores per sq. cm. Guidance for above will be highly appreciated.
D.T.THAKUR
- Colaba, Mumbai, India
A. Mr Thakur,
The MP chrome system functions to increase corrosion resistance as follows .
Creating 20000 potential sites for corrosion on 1 sq inch, the corrosion potential is reduced to that extent. Hence it follows that corrosion resistance is increased in comparison to a non MP chromium system.
If the holes are closed the resistance will equal that of a non MP system. The holes need to remain open.for the MP system to function.
Ideally, most plating standards call for 0.2 to 0.3 chrome thickness over Nickel when MP chrome is used.
0.5 microns chrome over Nickel is prescribed in some DIN stds. for non MP chrome.
asif_nurie
Asif Nurie [deceased] [deceased]
- New Delhi, India
