CADMIUM PLATING SPEC 'MAC PS 13101'
NEED TO FIND A SPEC FOR CAD PLATING. "MAC PS 13101" IT MAY BE OUTDATED BUT THE PRINT CALLS FOR IT.
JOE MAGPAYO
- ORANGE, CAL.
Joe, since MacDonnell Douglas became Boeing St. Louis, they've done some switchover to Boeing specifications: but I don't know what they've done on this one. At least you now know the source of the document, and perhaps your customer can get you a copy. Good luck!
lee gearhart
Lee Gearhart
It is a MacDonald Douglas spec. Needless to say you need Boeing approval to work to this, have a word with your Boeing rep about it - He can show you where to look.
Martin Trigg-Hogarth
surface treatment shop - Stroud, Glos, England
As far as the MAC PS 13101 specification? I think you actually want DPS 13101 and check with your local platers for this. Your plater will need to be certified to perform this, so knowing the exact specifications won't help you much if your plater is not certified.
Ron Graham
- Salt Lake City, Utah
