  Thread 160/48
Internal rust on zinc plated tubes
Can any of you solve my problem please. I have some tubes which are bent at various angles which are used in fuel and power steering assemblies. I am doing zinc electroplating with yellow/olivedrab passivation on them. The problem I have is, after plating the tubes are getting rusted inside very badly just within a day or two. As these tubes are for fuel and power steering the tubes cannot have rust inside.
Johnson
- Chennai, Tamilnadu, India
publicly reply to Johnson
A. Hi, Johnson,
It is a lack of information about your process to solve your problem completely:1.size of tubes;2.whether Zn coating inside of tube is necessary;3.Zn plating process you use(acid or alkaline);4.is it rack or barrel processing?
However, it is clear from your description that corrosion occurs because Zn coating on the inner surface of the tube is too thin (if at all it absents). So,if you don't need Zn coating on the inner surface of the tube, it necessary to close edges of tubes and prevent access of solutions inside. If Zn coating there is necessary you can use specific anode system.
Best wishes,
Mykolas Gladkovas
- Toronto, Ontario, Canada
publicly reply to Mykolas Gladkovas
A. You do not mention the length or diameter of the tubes. Generally even with 100% throwing power the penetration coverage internally of the tube would be as deep as the diameter of the tube , decreasing to no deposit with depth. That is if you were using say a 2" diameter tube , only 2" long you would have a chance of getting half the thickness plated on the outside of the tube at the halfway mark 1" inside the tube. On a 2" diameter tube say 6" long you would have an area of 4" in the inside of the tube totally bare. And that applies to straight tubes. Bent tubes would probably have poorer internal deposit distribution. It would appear that electroless plating would be the answer to your problem , as you would get uniform thickness both internally and externally.
Raymond Sebba
- Cape Town, South Africa
publicly reply to Raymond Sebba
A. This is a problem particularly in monsoon months here. What you need is a solvent based neutral ph polymer based film coating that does not attack zinc plating and forms a 1-2 micron coating on the inner side by simple dipping.
Khozem Vahaanwala
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
saify logo
publicly reply to Khozem Vahaanwala
A. Johnson,
Here's what you need to do.
1) Plate the part in an Alkaline Cyanide free zinc solution.
2) Optionally use an auxiliary anode if you wish , to get the zinc to deposit inside the tube. Yes, this is done in Delhi and Pune.
3) Assuming you don't go for the No 2 option: Rinse after plating in a final rust inhibitor water shedder.
Rinse that's available in Chennai from a supply house.
asif_nurie
Asif Nurie [deceased] [deceased]
- New Delhi, India
publicly reply to Asif Nurie [deceased]
A. Hi, I'm also working in tube plating since last 15 years. Rust is due to chemical filled inside tube. So plug the ends of tubes so that even water drop does not go inside. 100% your problem will be solved.
Ramchandra Talwande
- Baroda, Gujrat & India
January 29, 2012
publicly reply to Ramchandra Talwande
Q. What do you recommend plugging the tubes with.
Best regards
Mark Snyder
- Sturgis, Michigan
February 9, 2017
publicly reply to Mark Snyder
A. Hi Mark. Vinyl plugs made for masking for plating service are a commodity item available from half a dozen suppliers. If the temperatures somewhere in the process are very high, silicone plugs are also available at greater cost. Good luck.
February 2017
publicly reply to Ted Mooney
finishing.com is possible thanks to our supporting advertisers, including:
maskcoat banner
