Looking for aluminum alloy composition information
Q. Anyone know where I can find a list of aluminum alloys and their compositions. Specifically I am looking for the make up of #6082, but I would like this info for all alloys.
David A. Kraft
- Long Island City, New York
similarly
similarly
similarly
I WOULD LIKE THE COMPOSITION OF AU4GT4 MATERIAL. THANKS
SHANKAR
- ABU DHABI
I know that 1100 aluminum has about 0.95% Si + Fe. Could someone tell me how much of that is Fe?
John Adamik
- Gloucester, Massachusetts
We are having problems locating 2 x 6 alloy 1100 stock for machining high power waveguide components. Alloy 1200 is being offered as a substitute. Where can I find specification data sheets for al 1200. resistivity and tensile strength are critical design factors for our applications.
TOM BRASHEAR
- VIRGINIA BEACH Virginia
I need the composition and common products for the B90 Aluminium Alloy. Thanks.
Asier Fernandez
I would like to have a chemical composition detail on ASTM 209 3001 & ASTM 209 5011 along with whatever possible data. Thanks!
Kedar Vadhavkar
- Mumbai, Maharastra, India
I am looking for info on an aluminum alloy 3102 H02 in Billet form. Composition. Application. Current price. Any info would help. many thanks.
Greg Carrino
- Ramsey, New Jersey
I would like to know the mechanical properties of AG3NE aluminium alloy. Could some please help me.
D.K.Lahiri
Bhabha Atomic Research Centre - Mumbai, Maharashtra, India
I am looking for the composition of Aluminum alloy #5252
Joseph Aliotta
- Newton, Massachusetts
I am interested to know the exact or equivalent IS specification for Aluminium Alloy of composition cu.-3.5/4.5, Mg-1.2/1.7,Si-O.6,Fe-0.6, Mn--0.6,Ni-1.8/2.3, Zn-0.1, Ti-0.2,Pb-0.05,Sn-0.05, Al- rest.
The above has IS designation as 2285/BS designation as LM 14. Thanks
P.L.Narasimhan
MACHINE WORKS - coimbatore,Tamilnadu, India
Does anyone know where I can find properties for aluminum alloy 7004T6-T651? Specifically I need Chemical Composition, Physical Properties, Mechanical Properties Young's Modulus, Poisson's Ratio, Yield Strength, etc.
M.Anees
- Islamabad Pakistan
I am looking for the chemical composition and the mechanical characteristics of the ALU7G aluminium alloy
Chirita Ionel
- Romania
A. Alloy 6082:
Si: .7-1.3%, Mn: .40-1.0%, Mg: .6-1.2%, Fe:.50% max, Cu:.10%max, Cr:.25%max, Zn:.20%max, Ti:.10%max, Others:each:.05%max,total:.15%max
For all other alloys, you can contact ISO International Standards Organization.
Timur Ulucak
aluminum extrusions & finishing - Istanbul, Turkey
A. You can find a comprehensive list of aluminum alloy composition data at www.matls.com.
Charlie Hayes
-Minneapolis, Minnesota
A. ASM has a book, Aluminum and Aluminum Alloys[this on Amazon affil links].
Lee Branch
Richmond, Virginia
Q. I am looking for details-compositions on Aluminum Alloy LM-4 and LM-26. Thanks.
Kishore Sanghvi
USA
A. Detail composition of LM4 and LM26 are as under:
contents. LM4 LM26
Fe. 0.80 1.20
si. 1.6max 8.5-10.5
mn. 0.3-0.7 0.50max
mg. 0.15max 0.5-1.50
cu. 2.0-4.0 2.0-4.0
zn. 0.50max 1.0max
ni. 0.30max 1.0max
pb. 0.10max 0.2max
sn. 0.05max 0.1max
ti. 0.20max 0.2max.
Kirtikant Vakharia
Q. Does anyone know where I can find properties for aluminum alloy 7075 T651. Specifically I need, Young's Modulus, Poisson's Ratio, Yield Strength.
Felicia Brittman
A. Aluminum 7075 T651 specifications are available in www.matweb.com/search/Datasheet.aspx?MatlD=9595
S.Mathivanan
- Coimbatore, Tamilnadu, India
July 22, 2008
Q. Please guide to find an AISI equivalence for the ancient named aluminium alloy with specification L.72 (WW2?). Need its equivalence to perform an old aircraft repair.
Arturo Jacoby
Aircraft consultant - Santiago, CHILE
December 5, 2012
