Electroless Alumina Coating
Dear Sir/Madam,
I would like to know if there is a process to coat Alumina on Aluminium (0.05 mm thickness)by electroless method? I am looking to substitute plasma spraying of Alumina by a simpler/ cheaper method whereby there is no loss of strength or abrasion/wear resistance of the coating.
Thanks and regards,
Rajeev Rao- Belgaum, Karnataka, India
Are you doing this type of job i.e. plasma coating on metal rings to be used as seal rings in pumps.
Sekhar Biswas- Calcutta
