Name of ore aluminum is found in
Q. I am stuck on a question. I need to find out what is the name of the ore which aluminum is found in.
Phoebe Halliwell- Sydney
Bauxite is the most widely used source of aluminum; there are several others. Check out this link: www.citycollegiate.com/aluminium1.htm George Brackett III- Utica, New York You are stuck because you did not make much of an effort. Open up any encyclopedia, look for aluminum and you will have an answer that you can use for a reference. Nothing that you get from a chat room should be used as gospel unless you know the qualifications of the person that responded. Example, If I told you that iron comes from Taconite, it would be true, but only one of the sources. James Watts- Navarre, Florida
Hello Phoebe! ![]() Lee Gearhart metallurgist - E. Aurora, New York Hi Phoebe. Your mental tires must be bald today if you're stuck on that. I typed 'aluminum ore' into google and didn't even have to follow a single link! It says right in the abstracts of the first page hits: "The chief ore of aluminum is bauxite, a mixture of hydrated aluminum oxide (Al2O3·xH2O) and hydrated iron oxide (Fe2O3·xH2O)". Good luck. ![]() Ted Mooney, P.E. Striving to live Aloha finishing.com - Pine Beach, New Jersey
Ms. Halliwell, ![]() Paul Tibbals, P.E. gas & electric San Ramon, California, USA (My opinions are not related to nor a statement of my employer's) |
Bauxite ![]() Bill Reynolds [deceased] consultant metallurgist - Ballarat, Victoria, Australia We sadly relate the news that Bill passed away on Jan. 29, 2010. The most common aluminium ore is bauxite. There are plenty of web pages describing the extractive metallurgy of aluminium for its ores. ![]() Trevor Crichton R&D practical scientist Chesham, Bucks, UK |
