Metal Pretreatment
What is the life span of Ammonium Bifluoride in a metal parts washer application? What would the concentration need to be for this application to completely degrease and etch zinc cast parts?
Virgil Bryson- Dalton, Georgia, USA
Hi Virgil,
Ammonium bifluoride has no degreasing ability. It is included as a component in proprietary metal pretreatment products to do the etching job that you mentioned. But other components in the formulation will do the cleaning.
It is difficult to give a minimum concentration of fluoride because the etch rate is dependent on several factors. Your best bet is to contact a chemical pretreatment vendor, who can recommend an appropriate formulated product.
- Naperville, Illinois
