Gold precipitation
Explain to me gold precipitation with sodium metabisulphite, and give their reactions, ok? I am a diploma chemical engineer
Bhavin Sadadiya- Surendranagar, Gujarat, India
2002 2nd request
Hi,
I want to know the process of gold leaching with HCl by using hydrogen peroxide as an oxidizing agent. please give me the answer of my question.
Thnx for favorable reply bye,
I'm very interested in your question. If now you have answer of your question. Please tell me . I'm studying gold leaching.
- Thailand
Gentlemen,
There are several excellent books on precious metal refining available from International Precious Metal Institute (IPMI) as follows; Refining Precious Metal Wastes ⇦ on
AbeBooks or
Amazon [affil links]
by C.M.Hoke and Small Scale Refining of Jewelers' Waste ⇦ on
[affil link]
by Roland Loewen. The books should answer most of your questions.
Good Luck & Best regards,
United Precious Metal Refining Co. Inc. - Alden, New York, U.S.A.
Some very fine precious metals are lost in furnacing within slags. Recovery using gravity concentration of slags is not the answer.
Is there a chemical method of extraction. CLS does not work because soda ash re-precipitates the metals at ph 7.
Can someone explain if simply hydrochloric acid will produce a chloride and what the reagent is to precipitate the metals. Sodium metabilsulphite works well under certain conditions and is selective as a reagent.
hobbyist - Braidwood, NSW, Australia
I would like to find out is it possible to precipitate gold using sulfur dioxide.
Palesa DialeTechnician - Randburg, South Africa
sulfur dioxide, which is available in compressed liquid form in tanks, but is not cheap, can be bubbled through a glass tube to precipitate auric chloride to gold mud powder. Some experts prefer this method.
Wilson Wheatcroft- Holbrook, Arizona
I am jeya , a student of B.Tech Biotechnology . I have a question about the actual mechanism and percentage of recovery of gold using Chlorella vulgaris from goldsmith effluent.
To have a comparative study between Chlorella vulgaris and Scenedesmus quadricauda.
student - Coimbatore,Tamil Nadu, India
February 26, 2008
i did not neutralize the nitric acid and tried to precipitate with sodium metabisulphite, can neutralize acid after what is the process to save gold
reggie vegahobby - tukwila Washington
December 28, 2010
