Seeking activation for solder and electroless nickel
Q. Solder turns black and takes no Electroless Nickel.
I'm plating copper parts that have soldered plugs in them and when I get them back the solder is black with no Nickel over the Plugs. Any idea would be helpful.
david Psa
- san jose California
December 7, 2020
QUICKSTART:
Electroless nickel only deposits on materials that are catalytic to it like iron and nickel. To get it to deposit on copper, a typical down & dirty way is just to apply rectifier electricity to it for 2 or 3 seconds to get some nickel electrolytically deposited on the copper. Some people call this "sparking it" :-)
A. Hi David. It probably depends a bit on the solder composition. If it has lead, heed Dave's suggestion that a fluoride acid activation is necessary. After that, you probably have to 'spark' it because the solder may not be catalytic to the nickel, and the copper is certainly not.
December 2020
Q. I need activate a part for Electroless nickel plating that consists of the following substrates:
1. Electroless Nickel
2. Solder (88% Lead, 10% Tin, 2% Solder ^ Silver)
3. Nickel Beryllium (1/2H Brush Wellnan Alloy 360)
Currently, the solder does not plate.
William C. Carlson
- Coon Rapids, Minnesota
A. 2% silver maybe?
The only way is with fluorides. Fluoboric acid activator followed by Nickel fluoborate strike followed by your electroless. The big problem here is that the Lead is a catalytic poison for e-less Nickel process...so you have to cover it over with the strike first. Sounds like a unique application since commonly the nickel is deposited first. If contacting the part for a strike is impossible you may, with a bit of experimenting, convert the Tin/Lead/Silver surface using Palladium Chloride. This gives a great catalytic surface for E-less to take off on.
Dave Kinghorn
Dave Kinghorn
Chemical Engineer
SUNNYvale, California
