Coating PTFE onto Aluminium
Dear reader,
I want to coat PTFE coating on Aluminium base metal. Kindly advice if there is any process or I should use different grade (release agent?) of coating material.
Sebastian Klovar
- Celje, Slovenija
The question is not very clear but it appears that you need a release coating. Is the substrate a mold? PTFE coating is certainly used in release applications in a very wide range of applications. Aluminium is a great base for PTFE coatings, you need not change that. However, depending upon your application you will need to select the grade of PTFE or other fluorocarbon based release coatings.
Gurvin Singh
Mohali, Punjab, India
