Gold plating on nickel-base steel
I am an M.S student of metallurgy engineering and my M.S project is about "Gold plating of Nickel base Steel". Do you have any information about papers in this subject? Do you know any researcher who work in this field? If you know it is your favor if introduce me them.
Your sincerely,
Vahid Zaker- Tehran, Iran
Dear Vahid Zaker,
Gold plating on Nickel base steel is very easy its plating sequence and procedure is given in any metal finishing directories or any electroplating hand books. Thickness of gold plating is very Important these gold baths are of various types e.g., nickel-gold, cobalt-gold, iron-gold and alloy gold baths, each bath has got its own efficiency of deposition. As per efficiency current density , time will depend. This above data may help you as a supporting data.
Good Luck,
Panjala Mukesh
fashion jewelry mfgr.
Hyderabad, India
please tell me about electroplating in nickel (steel). with cleaner and chromium and so on. thanks
Rizwan Qadir- Lahore
Hello Rizwan. Your question except requires two or three hundred pages to answer, and just isn't something that can be done as an internet posting. Please take a look at our "must-have book list" and obtain any convenient plating book on the list. Good luck!
