Worn Silverplated Flatware
I have several pieces of silver plated flatware that I had been using as everyday utensils until I noticed how a considerable amount of the silver has worn off to expose a goldish and/or grayish metal. I am concerned about the safety of using this flatware now, especially since I have a four and seven-year-old. Thank you.
Shannon Bush
- San Antonio, Texas
Silver Plating Solutions
silver_eplating_soln
It's certainly appropriate to have them replated by a plating shop. Shannon, but I wouldn't worry about the hazards of eating off of this; there is no lead or mercury or cadmium or anything like that in flatware. There is "nickel silver" (contains no silver) and it does give a metallic off-taste.
What you're probably seeing is the underlying nickel plate layer, or if your set is old enough, the actual base metal, showing through. At any rate, the only fix is to have them replated by a professional. Check with the manufacturer (if they still exist). If it's Oneida, they should repair/replace them for no or moderate charge.
George Brackett III
- Utica, New York
I would like you to advise me if I can feed my daughter in a silver plate, will it be harmful or not.You can give me the advantage and disadvantage for eating in the silver plate.
Jennifer George
Interior Designer - Chennai, Tamil Nadu, India
March 15, 2010
Hi, Jennifer. Silver has been the standard for flatware and serving plates for centuries. It's hard to imagine anything less harmful except perhaps glass. Good luck.
March 16, 2010
