Brass plating problems
Hello
I have a small electroplating process. I am much obliged to you if you guide me.
IMRAN MAJEED
- tecart
In order to help, you need to tell us what of plating you do (nickel, brass, copper, etc.), the make-up of your solution, the parts you are trying to plate. A good source of information to begin with is the Metal Finishing Guidebook, from the National Association of Metal Finishers or the American Electroplating Society. You may be able to obtain an old copy from an existing plating company in your area.
Gary Patigler
- Electro Forming Co. Inc.
