Painting on zinc
Can you recommend an economical coating (paint, plating, etc.) process for use on a zinc alloy casting (ZA-8)? This part needs to be black for appearance only.
Patricia J. Volpe
Sears Manufacturing
I too am interested in painting new zinc castings with a spray-applied coating (black). Has anyone found a cleaner/primer/paint sequence which was successful?
Ernest Cox
APEX Industries
Is there a way to spray zinc on parts to achieve a uniform even coat?
James Gagne
Vangaurd Building Systems Inc. - Wells, B.C.
