Dissolving Copper Not Nickel
I would like a material that will dissolve a copper coating on electroformed nickel. Is there a commercial solvent that will dissolve the copper but not affect the electrode formed nickel at all? The context for this question is a process that uses copper as a release layer for a nickel cylinder that is electroformed from a mandrel.
Paul Gorenstein
- Cambridge, Massachusetts
My Metal Finishing Guidebook says you can use a solution of 90 g/L NaCN and 15 g/L NaOH, room temperature, 6 V, work is anodic, and use a steel cathode. You need to reactivate the nickel in HCl prior to replating.
James Totter
James Totter, CEF
- Tallahassee, Florida
I've got some recipes for you:
A commercial stripper is "Enstrip C", 100 g/l , temperature 21-29 C . You can buy it by Enthone Inc.
Other "home-brew" strippers are: Sodium sulfide:230 g/l,sulfur 16 g/l.Boil to dissolve sulfur. Use at room temperature.Brush off loose sulfide.Rinse and dip in 10% sodium cyanide solution.Repeat several times.
Or: Sodium sulfide:100-200 g/l. Use at room temperature.
Or: Mix 1 liter ammonium hydroxide (25%) with 0.1 liter hydrogen- peroxide and 1 liter water.Use at room temperature.
Kind regards,
Sjamp van Esch
Sjamp van Esch
- Eindhoven, The Netherlands
