ELECTROLYSIS PROCESS FOR SILVER RECOVERY FROM HYPO
Dear Sir,
I have a machine for extraction of silver from waste hypo solution. But it works better only with the waste X-Ray Hypo solution, it does not work with the photographic hypo solution.
What actually happens is when I pass current thro' for a sufficient period there is an yellow coating over the cathode ,this happens only with photographic hypo solution. I would like it (the machine) to work better with the photographic solution.
An early response is awaited.
Thanking you,
Ganesh.K.S- Trichy, Tamilnadu, India
