Chemical post-treatment (di-chromate) for zinc plating
Request technical/application information regarding zinc plating and di-chromate treatment for fasteners (lock washers) to prolong life due to functional wear.
Barry M. Pleska- Amherst, Ohio
There is a lot of information on zinc plating. (Current zinc plating nearly always comes with dichromate treatment) What do you need to know? If you are looking for a quote, this website has a big list of advertisers to choose from. If you are looking for technical information, then you have to be a bit more specific.
Tim Neveau
Rochester Hills, Michigan
