Silica removal from raw water
"Water quality & Treatment"
by American Water Works Association
water_qual_and_treat
AbeBooks
Did anybody hear about the possibility of removing Silica from raw river water by the dosing of ferric? raw water conc. is between 20 and 80 mg/l. Would be nice to have some info about that.
Thanks in advance,
Ulrich Mende
- Hilden, Germany
Although silica can be removed by adsorption on an iron floc,the efficiency is low. The preferred method for silica removal would be hot process lime-zeolite softening. You would be able to reduce your silica level to ~1-2 ppm.
Colin Mckay
- Johannesburg, South Africa
Normally Silica tends to get suspended in water at an elevated pH of 10.6 and above at 35 °C.
A burnt Dolomite (20% of MgO and 40% CaO) will fix the Silica completely.
Try it out.
Suresh K John M.E.
- TN, S.India
