Fabrication of multi junction thermocouple
I am working on a 'hyperthermia' project, to monitor spatial temperature, it is required to fabricate a multi junction thermocouple of 50 micron diameter with proper electrical insulation. The temperature range is 20 to 50 °C. If someone can give me some info about fabrication process and material selection it will be helpful for me.
Amol Valmik Patil- Maharashtra
You need to use platinum wires, quartz glass "U" tubes compensating cable etc.
Manish Thatte- Nashik, INDIA
