Q&A: Rhodium plating silver rings & jewelry
Q. I own a rhodium plating firm and doing job work of brass jewellery. Recently I have come across a challenge: I am told to do silver jewellery without copper and nickel, i.e. nickel-free, copper-free. I am doing Ultrasonic cleaning, Electrocleaning after that, and rhodium -- but the piece is not having any colour and is turning black. But when I am doing with nickel the colour is coming perfect. What process needs to be added?
Ankit shukla- Kolkata West Bengal, India
August 7, 2020
A. Hi Ankit. The usual answer to nickel-free is "white bronze". It's not copper color, it's nickel color -- but it contains a lot of copper. Do you have any information on why this plating is required to be copper-free, especially when the ring itself is not? That could be an interesting discussion point.
Reflectivity is partially a question of the type of metal, but it's also an issue of surface topography. Maybe the ring could be better polished before the silver plating, and plated with a heavier layer of silver to insure it is not porous.
Q. My company is purchasing sterling silver jewelry as a promotional item. We do not normally buy jewelry, so I am not very knowledgeable about it. I received samples from a trader in China. The samples are very bright, brighter than most silver in department stores. The packing slip stated silver plate finish, so inquired as to whether or not it was 925 sterling silver or just plated. They have assured me that it is 925 sterling silver, but with a silver plate finish as opposed to a rhodium finish. What is the difference (other than price)?
Michelle R [last name deleted for privacy by Editor]- Fayetteville, Georgia
A. Michelle, Rhodium belongs to the Platinum group of metals. All of them present outstanding chemical inertness (will not react or change easily) thus, rhodium will not tarnish whereas silver will. They are very expensive, so only a very thin plate is applied to reduce the amount of metal in the jewel. If not subject to excessive friction and wear, they will retain their look indefinitely. Guillermo MarrufoMonterrey, NL, Mexico A. You are right that the price of silver and rhodium are very different. Today silver is $4.66 per Troy oz. and Rhodium is $925.00 per Troy oz. It is not uncommon for manufacturers to silver plate sterling silver items. They do this for two reasons. First, the silver as plated from a bright bath is brighter than can be achieved by polishing; and second, the fine silver deposit will tarnish a little slower than sterling silver. Rhodium is much harder and will not tarnish at all, but aside from being expensive it is also a little bit gray compared to silver. Neil BellAlbuquerque, New Mexico |
Q. I retail only one ring as a novelty item so I try to keep my price down. It has been brass; however, my supplier suggest that I do a rhodium finish on the brass. Would that fix the tarnishing problem or should I just go ahead and do a silver ring with a rhodium finish?
Michelle S [last name deleted for privacy by Editor]- Nashville, Tennessee
A. Rhodium plated silver is the best type of silver to buy on the market cause it will never tarnish, looks better than real white gold, and a tenth of the price.
Jake T [last name deleted for privacy by Editor]- Brooklyn, New York
Q. I sell a great deal of costume jewelry and would like some help as to how to explain to a customer the pros and cons of rhodium jewelry vs. sterling silver. I have found that many customers have no idea what Rhodium is and feel that sterling silver is much better, since it is "real". Any explanation and help regarding the above would be very much appreciated. Thanks.
Jean RamsayBuyer - Lexington, Kentucky
A. The basic issue, Jean, is that silver tarnishes. Although some people like that natural look, many don't, and it can be hard to offer & sell tarnished jewelry at your jewelry counter.
So we look for ways to delay or prevent that tarnishing and one of several ways to do it is to plate a very thin layer of rhodium on top of the silver. Rhodium is a precious white metal that doesn't tarnish and is never significantly less expensive than gold and sometimes 10x as costly as gold. So there is nothing cheap or duplicitous about rhodium plating silver jewelry, and your customers should be able to understand the situation easily.
The difficult customers would be the ones that demand a natural silver that will readily tarnish, but they will probably want it to be shiny and untarnished when they buy it! This demands either careful protection with anti-tarnish packaging and/or constant polishing until you sell it :-)
A. I have read all the comments, and haven't seen a message posted by a manufacturer. I am a manufacturer of high end silver jewelry from Thailand, exporting mainly to European countries. So I would like to share manufacturer's perspective.
As you guys said, rhodium is much more expensive than silver plating. But it's worth it if your market is high end. Because apart from the fact that silver plating can be tarnished easier, it also can be oxidized easier (look not shiny and gone black).
Rhodium, if proper plating is applied, will be more shiny and durable for a long time.
For the point that rhodium is a little bit blacker than silver plated, in my opinion, I think it looks like white gold jewelry, because white gold jewelry is also plated with rhodium. My company does high end product and the design is in line with gold jewelry, so all products are rhodium plated.
For the point that when they said silver plated, is the material is silver or just plated with silver? Looking on the back side, if it is stamped 925, it is made of silver.
Kulthida PiankijagumSilver Jewelry - Bangkok Thailand
April 3, 2008
Q. Rhodium plated jewelry and sterling silver wash so quickly on me, am now afraid of getting them yet; the Brazillian yellow ones last well on me but the white ones still don't last at all. They become hard every day I wear them and have to rinse with water and then dry before they get flexible again. Hobbyist - Lagos, Nigeria September 14, 2011 |
A. Natural silver, while requiring a little effort to keep it's shine is a much nicer finish than the others suggested.
Jay Stell- Ljubljana, Slovenia
October 28, 2011
Q. I just bought a "925 sterling silver filled" ring from eBay , and I loved it, but when I got it, after wearing it after a day my finger had a green ring when I took it off. I'm kinda upset about it. Did I buy fake silver? And what makes the green ring on your finger? My other silver rings did not do this. Crystal Chaviers- Linton, Indiana USA July 31, 2012 A. Hi Crystal. "Silver filled" means it has a thick plating of silver, with silver comprising 10% of the weight of the piece, and other metals like copper comprising 90% of the weight. It is not solid 925 or Sterling silver. I am from the plating industry, not the jewelry industry, so I can't comment authoritatively on misleading advertising, but "925 sterling silver filled" certainly fooled you & others, didn't it? The underlying metal is copper, and copper salts leaching through the coating is probably what is turning your finger green, although it surprises me that it could do so if the cladding is actually as thick as advertised. Regards, ![]() Ted Mooney, P.E. Striving to live Aloha finishing.com - Pine Beach, New Jersey |
Q. Dear Ted,
Which is more popular between regular 925 and rhodium plated 925 in today's market? Thanks.
Khin Goodkin.
- S Ozone Park, New York
September 18, 2012
A. Sorry, Khin, I'm not in the jewelry industry and would not know the relative popularity ... but rhodium plating isn't the only anti-tarnish treatment for silver either.
I want to know whether is it necessary to have a base of nickel before plating of rhodium over silver, or we can directly plate rhodium without base?
jewellers - Indore (M.P), India
December 10, 2012
A. Hi Guarav. No, it is not necessary ... if we are working from the same assumptions. A common use of rhodium on silver is not to give silver a permanent rhodium look, but as a temporary anti-tarnish treatment, so that it can be put in a showcase for display and sale without constant re-polishing.
If you are selling it as special non-tarnishing silver, however, then you probably would need the longevity and freedom from porosity of nickel (or white bronze) plating, and/or high purity silver plating under the thin and porous rhodium plating. That's my understanding.
December 12, 2012
Q. I have some sterling silver pieces that I gave to a jeweler to Rhodium plate. The pieces had some tarnish on them, one chain was clean though, no tarnish. When they called me to pick up the pieces all of the tarnished pieces looked yellowish and the color of stainless steel with little shine, while the clean piece came out immaculate. I'm familiar with rhodium on gold. I understand for silver they need to use another metal such as nickel as a barrier between the silver and rhodium. I was told by the jeweler that the color of the rhodium is dramatically affected by the quality of the silver and that most of my pieces were poor quality silver. I don't buy this. I believe that they didn't polish or properly clean the tarnish off prior to applying the rhodium. Please advise. Does the quality of the silver, all 925, affect the final color of the finish? My understanding is the rhodium should be bright white and shiny regardless of the metal being finished.
Becky
- Little Egg Harbor, New Jersey, USA
June 13, 2013
A. Hi Becky. There are a dozen reasons for various colors and 101 for misunderstandings. Unless we understood thoroughly what the jeweler did and said he did it's unfortunately very difficult to form any opinions.
Sometimes a heavy layer of rhodium is plated over a layer of nickel or white bronze to give that scintillating look of white gold engagement rings; Kulthida P says his company offers that kind of high end costume jewelry. Other times a very thin and virtually transparent layer of rhodium is applied just to deter tarnish, leaving the soft color of silver. Then too, most jewelry shops are not high end multi-million dollar instrument controlled electroplating factories; often they're virtually plating out of a tea cup with a $400 plating setup and contaminated solutions and that causes discoloration.
Maybe try another jeweler and carefully explain that you want your jewelry to look like his white gold engagement rings, and get the agreement that he can or can't do that before you commit. Good luck.
Ring is not stamped; is it sterling?
Q. I bought a ring they claimed was 925 silver plated with rhodium but the ring is not stamped 925 the only markings I see on the ring is CHINA GM. What does that mean? I have never seen this marking before. By the way the ring looks gorgeous and looks as shiny and new as the day I bought it. Also has a number of brilliant cz's in the sun.
Pat Caldwell- Summerfield, Florida, USA
September 25, 2014
A. Hi Pat. Sterling is usually stamped "925" or "sterling", but so what? Silver is only a semi-precious metal and the intrinsic value of a small silver item like a ring isn't much anyway; the important thing is how it looks to you and how durable it is. So don't worry, be happy :-)
Q. Good Morning,
I have a small start up company and we make sterling bracelets and souvenir charms. However I am having a problem with my manufacture. Now that I have over five hundred charms to sell, I find the rhodium plate seems to dull inside a month of wear. I discovered they were plating a thickness of 0.05 microns (?). What is the proper thickness for lasting rhodium, and can I re-rhodium the charms I have that have been unworn. We bill ourselves as high end luxury jewelry and cannot afford the discoloring of our jewelry.
Colleen
- naples, Florida USA
January 23, 2015
A. Hi Colleen. As I've said earlier in this thread, I could be wrong because I'm not a jeweler and all I know about this subject is just from handling hundreds of these Q&A's. But let's review my understanding, and I hope that you or someone will correct me if I'm wrong ...
Some people love the soft look of silver, even though silver quickly tarnishes. But even if customers like that look, and even if they completely understand that silver tarnishes and are content to deal with it, they may not want to buy brand new tarnished silver, and jewelers may not want to try to sell it to them, because it looks dirty or used instead of new. For this application, rhodium is sometimes applied in a very thin layer (yes, about 0.05 microns) to forestall tarnish through the display & sales period (there are other alternatives to achieve the same end, including preservatives and organic or inorganic clearcoats).
But other people love the scintillating bling-y look , and they want the bling to last, not to fade as soon as they buy it. This group doesn't want their silver to look soft and to tarnish, they want it to flash like rhodium. It seems that you are selling to this second group. For this group you certainly need a significantly thicker layer of rhodium and you may need an underlayer of nickel or white bronze before the rhodium. The site's supporting advertiser Metal Arts Specialties has a good FAQ on rhodium plating at https://artisanplating.com/electroplating-faqs/rhodium-plating/
Luck and Regards,
A. Good day Colleen. - Whitby, On, Canada A. Rhodium is extremely difficult to electroplate crack free, especially with the jewelers who never learn the purity of the more sophisticated rhodium plating in the electronics industry. The silver corrodes right thru the cracks, Dip your parts in a cyanide solution, rinse, dip in 5% acetic acid ⇦ this on eBay or Amazon [affil links] and apply an organic tarnish retarder. ![]() Robert H Probert Robert H Probert Technical Services ![]() Garner, North Carolina ![]() |
Q. Each reply here seems to point to the cleaning the material before the plating process, including a bond of an in-between metal before the final bath of rhodium. I have to reread some of the answers to fully understand the cleaning system. I was originally told something simple as a jeweler's pickle for a cleaning process, however this apparently is too simple?
My manufacturer has volunteered to recall all of my merchandise and correct the problem. (yes, my clients are the bling-y types) he is suggesting white gold plating which I am suspect. The key I must pass on to him is the cleaning and the nickel plate in between.
My net understanding is that the procedure for cleaning and plating is too complex for a home laboratory?
January 25, 2015
Hi Colleen. Yes, cleaning is essential. The jeweler's pickle will remove the oxides and sulfides, but not oils, greases, and fingerprints. In production, the usual cleaning is by immersion into strong hot alkaline solutions. But for low volume custom work the pieces can instead be scrubbed with a tampico brush and a solution of fine powdered pumice & detergent. The sequence is clean, rinse, pickle, rinse, plate.
But if you think that you as a customer can gather information on the internet to instruct an inexperienced plater you will be disappointed. The plating shop needs to be experienced, and absolutely must not need to be told how to clean parts. Please consider sending a sample lot to one of the site's supporting advertisers, listed below, who are experienced jewelry platers. You probably will not be able to sell your stuff in Europe if you use nickel plating; so white bronze or palladium as an underlayer, or a heavy rhodium plating by an experienced shop could be a better idea.
I definitely hesitate to say that you can't do it yourself -- many jewelers do it themselves. Although general electroplating can be quite difficult because of the often complicated pretreatments required, but if you already have well prepared and polished silver charms and just need to scrub, pickle, and rhodium plate them, I think it's doable with patience and dedication. Good luck.
Q. Hi. I'm just an ordinary sales lady. We have accessories in our shops and most of them are "brass rhodium plated". Our customers are always asking what does it mean. I just want to have a short and clear explanation about it. They are asking if it changes color, or the shine will fade, etc. Please help. Thanks.
shane y [last name deleted for privacy by Editor]- dubai uae
May 19, 2015
Chemical dulled my silver bracelet
Q. My husband and I have matching wide silver bands that we purchased and have worn for over 15 years. Country of origin is Mexico and stamped .925. Neither has tarnished. Unfortunately mine has lost its shine due to a chemical reaction after dropping it into a Polident solution. What is the best way to restore the shine? Can any reputable jeweler fix this?
NANCY GRINSTEADbuyer - KANSAS CITY
November 9, 2015
A. Hi Nancy. If they were bright and shiny and didn't tarnish they probably had rhodium plating on them. Many jewelers can polish/buff it back to a shine and rhodium plate it. Good luck.
A. There is Argentium Silver which resists tarnishing but you have to be careful when working with it because if you touch it before it has cooled down from heating it with your torch it will crack. Also Pure silver can be work hardened and it will not tarnish. As for the items coated with Rhodium, this was very popular in the 50s and 60s, especially chains and charm bracelets. Women wanted the look of Platinum without the high price tag. Whoever said that lobsterclaw clasps were magnetic, that was incorrect because they can use other metals for the spring that are zinc based, hence not magnetic. Then we come to jewelry coming from China marked 925, well most of it is copper with silver plating. Hopefully they will start enforcing the same purity standards we have to meet when stamping our handmade custom pieces.
Patricia VieraMetalsmith & Lapidarist. - Columbus, North Carolina USA
November 5, 2016
Q. If a sterling silver piece of jewelry is rhodium plated may I still stamp it 925, legally/ethically?
Thank you!
- Brit shemesh, Israel
April 23, 2018
A. Hi Penny. If it was 92.5% silver before rhodium plating, it will be 92.5% silver after rhodium plating. I can't see see any confusion, legal, or ethical issue.
Q. Which buffs / polishing cloth can be used for the pcs after Rhodium plating?
Santosh PatilSunjewels Pvt. Ltd. - Mumbai, Maharashtra, India
March 15, 2019
White gold and rhodium over sterling silver ring
Q. I purchased a beautiful ring, but they say it is 'white gold rhodium plated' over sterling silver. What will it look like if the plating starts wearing and what is the average cost for re-plating? Thank you. Vickie
Vickie MillerBuyer - Shelbyville, Kentucky
October 30, 2019
A. Hi Vickie. I don't know if "average cost" has much bearing for sterling silver rings, because re-plating can cost more than a new sterling silver ring, but let's say $40.
A good quality ring ought to look good for a reasonable life because these metals are generally more or less the same silvery color, whereas if there were a yellow metal (brass, gold, copper) involved, the contrast would be much more obvious. But who you bought the ring from is a much better quality guide than any sales pap :-)
