Laser Scale Removal
What options are there for removing laser scale?
Cal Niemela
- Calumet, Michigan
Cal,
Presumed you need to get rid of the laser scale as preparation for (powder)coating,you can use following methods (we planned here in Europe several plants using these methods:
A: mechanical, such as blasting, grinding etc. Done only at lower quantities or if the sheet thickness is over min. 4 mm.
B: chemically (etching/scaling) as a part of the pretreatment-process before the painting. Can be done in dip systems as well as in spraying systems (stop and go and continuous running systems).
Remmelt Bosklopper
Remmelt Bosklopper
- Enschede, The Netherlands
