How to analyze salt spray solution
How to analyze salt spray solutions? Is there any specs with these details to follow? I didn't find on ASTM ASTM B117 .
Tony Chen
- New York
If you read the fine print, Note 11 in the std. I have B-117 -90. It states that a solution having a SG of 1.0255-1.0400 @ 25°C will meet the concentration std. There is also another method, titrating with AgNO3 in the same note.
George Shahin
George Shahin
Atotech - Rock Hill, South Carolina
Tony -
In the current version of B117 (97), paragraph 8 describes the solution relative to pH, specific gravity. The important fact to remember is that these measurements apply to the collected solution. You can adjust the mixture as needed (but within reason of course) in order to achieve the proper pH.
Cynthia L. Meade
- Sylvania, Ohio, USA
