Field test for verifying anodizing
Is there a field test to determine if aluminum handrails are anodized?
Joseph Mosca- Yorktown, New York
Use a volt meter the anodized film is not conductive. If it conducts electricity on the voltmeter it is not anodized or you pushed the probes too hard and broke through the anodized layer. You have to push pretty hard to break through the anodized layer. Todd Osmolski- Charlotte, North Carolina, USA 2002 The easiest way to check for an anodized surface is to use an Ohmmeter. An anodized surface is non-conductive. Curt Henderson- Ft. Wayne, Indiana 2002 A simple, and inexpensive test, would be to take an ohmmeter and test for continuity..as anodizing is a dielectric coating. ![]() Marc Green anodizer - Boise, Idaho 2002 |
