Water stain on wood
Have white water mark stain on walnut finish table. Had a planter in a plastic dish under it and this still happened. How can I remove?
Rose Johnston
- Hagerstown, Maryland, USA
Hi,
The waterstain could fade if you remove the planter. If it does not you will need to have the table top refinished.If you do ensure that a 2 pot lacquer is applied to prevent future water staining.
STEVE BEAUMONT
- NEW ZEALAND
