Paints for corroded machinery
Resp. sir,
I am working in a pickling industry. Due to acid fumes present in the atmosphere, there is lot of corrosion of our machinery in our plant. I came to know about a paint which when applied to the corroded part (even without cleaning the rust)forms a compound with the rust and coat the metal. I would like to know about the paint and any Indian manufacturers.
Vijayan Nair
- Mumbai, Maharashtra, India
TRY COATING THE RUSTED PARTS IN NATURAL FISH OIL. IT WILL SOAK INTO AND STOP THE RUST AND WHEN DRY CAN BE PAINTED OVER. SMELLS A BIT BUT WORKS WELL.
STEVE BEAUMONT
- NEW ZEALAND
Another approach might be to look for a "rusty metal primer". I tried this with several Internet search engines and found several paints designed for use with high temperatures and acidic conditions that are primarily marketed to the automotive rebuild/customizing industry.
Dave Hass
- Oklahoma City, USA
A special kind of blasting machine which can remove all the rust on a machinery without affecting all and any of the sensitive parts which are all in-situ, (these need not be removed)because the media is sodium bi carbonate.
In one hour it can strip out cleanly and back to pristine condition a machinery that takes a few hours through chemical stripping.
Rambo Ram
