Plating corrosion
Plating getting rusted while traveling in the sea for about an month. Black spots appears.(zinc plating yellow passivation)can you give explanation about electrolytic cleaning.
R.Balaji- Chennai
Difficult to remove these black spots, you will have to do a better job of preserving the finish by sealing with a post dip of some kind, or sealing in plastic bags with an inert atmosphere.
