  Thread 140/80
Removing sheen on ceramic tile
I would like to wallpaper over some existing ceramic tile. What do I need to use to help the wallpaper adhere to tile properly. Will muriatic acid this on eBay or Amazon [affil links] work, or is there something called liquid sandpaper to apply to tile? Help!
Kathy Wiestenberg
- Mpls, Minnesota
publicly reply to Kathy Wiestenberg
I, too, am interested in what preparation is required to properly wallpaper over ceramic tile.
Judith Paul
- Chocorua, New Hampshire
publicly reply to Judith Paul
This is not an easy answer, what you will need to do and what I have done in the past is use a belt sander and scuff the face of the tile, wash with clean water to remove all dust, apply a skim coat of tapers mud over the tile and smooth out and sand. repeat this until its smooth and dry. wipe down with some tack cloth ⇦[this on eBay or Amazon affil links] or something to remove dust, put up your paper. that was easy huh?
Sean Mulvaney
- Mpls, Minnesota
publicly reply to Sean Mulvaney
