Piston Tin Plating Problem
Q. Dear Sir,
We have had problems with adhesion of tin to aluminium pistons in the past plated in an alkaline potassium stanate solution. To overcome the lack of adhesion we air age for twenty minutes directly after removal from the plating solution and before rinsing. An independent study has found that conducting this air aging process can form crystalline deposits on the surface which are thought detrimental to the function of the part. I would like to know what are these deposits likely to be composed of? Are there methods other than air aging capable of increasing tin plate adhesion to a level comparable with that achieved by air aging? We use a simple adhesive tape method to assess adhesion.
Thanks in advance for any assistance you can give
Kind Regards,
Graham Dodd- Melbourne Victoria Australia
A. What is your reference for this air aging? I never heard of it. I would revisit your parameters of tin plating on aluminum for a permanent fix of the problem.
Thanks for the response Tom. Like many "great" discoveries this one was made by accident when several pistons were removed from the plating cell before the final rinse. There is some doubt whether the practice of air aging will continue as indications are that deposits on the piston may be detrimental to the end function of the piston.
- Melbourne, Australia
Q. What are the reasons for oxidation of Tin plated pistons? We are using Sodium stannate solution for tin bath. Does this bath have some life defined (as we are not making new bath only replenishing by adding chemicals)?
MANDEEP Singh- Punjab, India
April 1, 2016
