Coloring aluminum
Sir,
We are manufacturer of piston, I want to color aluminium in any color except silver.
Thanx.
Muhammd Idrees
- Pakistan
And your question is?
Marc Green
Marc Green
anodizer - Boise, Idaho
Hi sir,
I want to change the original color of aluminium metal (piston) what I should do . . . what composition of chemical should be used to change the color of Al. please tell me the most inexpensive way of coloring Aluminium . . . We are a manufacturer of Pistons.....
Take Care,
Idrees Aziz
- Lahore, Pakistan
Most inexpensive way to color aluminum:
Direct chemical coloring:
Brown to black color:
potassium permanganate this on eBay or Amazon [affil links] .......10 gm
copper nitrate this on eBay or Amazon [affil links] ...............25 gm
nitric acid(38 Be)...........4 gm
water........................1 lit
Hot immersion(80-100 C)!5 min=light brown,15 min =dark brown,30 min=black Golden yellow color: potassium permanganate......20 gm.water 1lit Hot immersion(8o C)!You can add 5 gm copper sulphate this on eBay or Amazon [affil links] for bronze color!
Red color:
potassium sulfide.......25 gm
o,3 gm potassium bichromate
alizarine................ 1 gm
water....................1 lit
Good luck! Only thoroughly degreased objects can be colored!
- Zagreb;Croatia
Hi there !
Could anyone of you tell me how to color aluminium in blue, both light and dark ? (The cheapest way, of course)
I am involved with motorcycle tuning parts.
Thanks in advance.
Oscar
oscar rivero
backyard mechanic - lagomar,canelones, uruguay
May 26, 2009
Hi, Oscar. To color aluminum for decorative outdoor application is a different thing than just trying to temporarily mark it for in-factory identification. You need to have a full polishing, cleaning, desmutting, anodizing, dyeing, and sealing process applied to these parts.
Talk to a local anodizing shop and they will explain, and maybe show you, what is involved. Good luck.
May 26, 2009
