Sound technical content, curated with aloha by
Pine Beach, NJ
Cathode Plate Thickness in Dummy Plating
I measured the thickness of our cathode plate; its middle calculated value is 1.914 mm. In dummy plating controls, the voltage meter and current meter displays respectively 1.6 dV , 1.5 mA. Who can think, that after two years of utilization of our cathode plate, its thickness evolve normally with this voltage and current values?
Mustapha HADJLAZER DUPLICATION - Oran, Algeria
I'm understanding about 1/3 of what you are trying to say, I think. Make your question three times longer and maybe I'll understand it :-)
