Powdercoating MDF vs. vinyl vacuum wrap
I have a part to bid on for powdercoating. The piece is essentially a 4x4x12 piece of MDF. The client is also taking bids to have the part vinyl vacuum wrapped. Does anyone know costs involved in vinyl vacuum wrapping? ($/sq ft)? I would like to have some idea as to how low (or high) the other bid may be so I can make my bid competitive.
Thanks for any help.
Robert John
- Evansville, Indiana
But what if the customer pulls the dirty trick of looking for a 2nd quote on powder coating? :-)
In order to powder coat MDF, either a conductive clear coat, or preheat of the MDF is required. Are you prepared for the risk of failure?
Herb Ashley
- Smartt, TN
Powdercoating gives a better quality then pressing, and it is cheaper if the dimensions from the pieces are not to small..
Koen Peters
freeform nv - Houthalen, Limburg, Belgium
