Please forgive the very slow page loading. We are suffering a Chinese DDOS attack thumbsdown it will pass.
Disposal of copper ion
What is the most effective and cost effective way of getting rid of a huge amount (400 liters a month) of copper ion solution, while keeping the water supply safe too?
Sean Pelusi
CU Plater - Butler, Pennsylvania, USA
You didn't specify the copper concentration or what the other solution constituents, but two things come to mind.
First, if the copper is relatively pure, you could ship to a recycler. There are several that accept copper for processing into chemicals and animal feed supplements. Another approach is to install an electrowinning system to convert the copper to a recyclable, metallic form, however, this assumes that the electrolyte is something like sulfuric acid that would make a good plating solution.
Lyle Kirman
