SULFUROUS ACID
I am looking for a chemical, that is not only economical, but will also bond with Sulfurous acid and not water...
Thanks ! :)
KATY SHUE
- SYDNEY, AUSTRALIA
Why?
Dan Brewer
chemical process supplier - Gurnee, Illinois
Interesting question. Sulfurous acid contains one less oxygen than sulfuric acid. Its made from SO2 + H2O instead of SO3 + H2O In any case, you buy sulfurous acid as a solution in water. I guess we need understand your question before we can help you find a solution to it.
Caleb
- Pullman, Washington
