HCN concentrations in plating baths
Gold plating baths can contain HCN at acidic pH's. As I understand it, the gold/cyanide bond will hold at lower pH's but the free cyanide has gassed off. Am I wrong in what I am thinking? In what concentrations can cyanide exist in an acid solution 4-6 range?
Kelly Smith
- Mount Vernon, Washington
Indeed there are acid gold cyanide plating baths much like you describe, and your understanding is correct. I don't know the maximum concentration of free cyanide (HCN or NaCN) that can stay in solution in this pH range, and it probably depends on a number of other factors like temperature, but it's not much--which is why acidifying cyanide solutions is so dangerous.
About/Contact - Privacy Policy - ©1995-2025 finishing.com, Pine Beach, New Jersey, USA - about "affil links"
