Electrolytic Paste
lindgren_bus50
Q. I would like to know what is Electrolytic Paste ? How it is used? How is it produced? Thank You in advance,
Juan Carlos Rodriguez
- Bogota, Colombia
A. Ya got me, Juan. Can you give me some context, please, so that I can clearly understand what kind of product you are referring to?
Q. I would also like more information on this product, it is used as an anti corrosion agent for grounding connections and exposed electrical connections.
The only manufacturer I know of is Denso
Cedric J. Baker
telecom - Hereford, UK
March 16, 2009
"No-Ox-Id" Compound
no_ox_id
Hi, Cedric. Sanchem offers No-Ox-Id compound Special A, which is designed for electrical contact surfaces -- things like bus bar joints and cable terminations. I think we're getting warmer :-)
Reputedly, the paste acts as a grease to facilitate a tight joint; and is electrically conductive; and it coats the components to deter corrosion at the joint; and some of these pastes dissolve the thin aluminum oxide on aluminum components to improve conductivity. Like everything else in the world, they probably work better than nothing and not quite as well as their most glowing sales literature :-)
Why grease cable terminations?
Q. Why do we put grease on metal (copper / aluminum) cable terminals?
Ahmed attia
senior electrical engineer - saudi arabia
March 5, 2015
13517NoOxId
A. Hi Ahmed. I doubt that it's actually "grease"; more likely it's a greasy compound designed for the purpose. We appended your question to a previous thread which explains its use.
